There's room in the shower CU for a 2nd MCB.
That unit would do, if your friend would want to consider removing the existing shower unit and replacing with the linked unit. You could still have shower unit on a 40A breaker and then protect the new sockets via 16a or 20a breakerThe electrician can't come for a couple of days but just so I can understand what's required, is it one of these:
http://www.toolstation.com/shop/Electrical/d190/Wylex+Consumer+Units/sd2615
BAS, there is and would ideally be an RCBO.There's room in the shower CU for a 2nd MCB.
There's already an RCD.BAS, there is and would ideally be an RCBO.
It's a 4-module unit - those ON-OFF stickers are on ½-width blanking strips. With those removed and the existing stuff shuffled along there'd be room for 2 MCBs and the RCD.how is there room in the shower CU?
What do you think requires an RCD to be installed where there wasn't one before?does combining 2 circuits count as work requiring addition of an RCD?
As the FCUs are being changed to socket outlets, you would suspect the answer to be that an RCD is required to cover those circuits, you could probably turn a blind eye to the any existing buried cable as it is not new.Can it not just be added to the existing socket circuit at the fuse board? Of course it ideally should be RCD protected, but does combining 2 circuits count as work requiring addition of an RCD?
(I suspect the answer is yes, but thought I'd ask anyway)
Is there? I have I missed something?There's already an RCD.
Can't the switch just be replaced by a combined RCD/switch then the MCB added to the E7 circuit?
There was one.Yeah, I cannae see it Jimmy either.
