Now I have this report I COULD send it off to BS which would cost me money, or keep it and provide it if asked =)
Whilst I've been generally siding with you, I'm a bit confused by the above statement.
I don't think we've established for certain whether the work in question was notifiable or not, but it sounds as if it probably was. Nor am I totally clear as to whether your electrician has simply undertaken inspection and testing of the work and issued an Electrical Installation Condition Report or somesuch or (if he is a member of a self-certification scheme) he has claimed to have undertaken the design and construction of the work and has 'self-certified' it (ant notified it to LABC) via his Scheme.
If it wasn't notifiable work, then LABC would have no interest in your certificate, and presumably would not charge you anything for having unnecessarily sent it to them. If, however, it related to notifiable work which had been undertaken without either prior notification to LABC or self-certification by an electrician who had undertaken the work and was a member of a self-certification scheme, then (regardless of whether one talks of laws or Acts
) you theoretically would risk prosecution (although no-one seems to have heard of such a prosecution) and they almost certainly would require you to go through a 'regularisation' procedure, the price of which is usually around double the normal notification fee (hence probably 'several hundred pounds'). They also might, theoretically, require you to expose all of the work, including cables buried in plaster etc. etc. (although they probably wouldn't!).
Kind Regards, John
Forget BAS he does this every time he wants to dot every eye and cross every T and presumably tootles along at 20 MPH as he passed a sign saying 20 even if it was all in the wrong colours.
We tend to get caught out with words some times and when I say dead test my first thought was to prove dead and I could not understand why it needed proving dead. I had called it pre-energising testing and simply did not at first realise what they were asking for.
I have many times waited for the supply electricians to arrive and bring in the supply often with daft comments like you should have provided a duct for our cables. And I had to point out the builder in 1750 likely did not envisage having electric power connected.
I think the idea of a main isolator is good but there does seem some debate as to if the supply authority or house holder should provide it. The idea is you can remove the supply without removing fuse and breaking seal.
In most cases we re-wire our own houses bit at a time and as such only the bathroom and consumer unit requires the LABC to be notified. There is some debate at what makes a new circuit where a fully populated consumer unit is installed then one could hide behind the fact all circuits already exist and your only extending them.
Having seen what the LABC do during an inspection before issuing the completion certificate I would not be worried about the certificate in my case all they did was rubber stamp my installation certificate they did not even visit before issuing the completion certificate.
To me to complete the installation certificate means one has to do a check list. One can make mistakes I remember where I had fitted a load of sockets which had line on one side and neutral on the other and with one odd socket it was reversed and I had missed it. Testing highlighted my error and it was corrected we all make mistakes.
As to who does the work well my son worked for a firm doing nothing but inspecting and testing the firm did not issue every electrician with test equipment he would tour around many sites testing. The only thing different from that to owner doing the work is who pays who. The apprentice system still exists and so does the electricians mate and I see nothing wrong with the system.
Clearly doing all the work than asking some one to sign off is very different but where the electrician has planned the work and given set jobs to be completed to apprentice or mate I see nothing wrong with the system which includes the owner mating for the electrician. Main thing the electrician is in control.
Personally I think every electrician doing inspection and testing should hold a C&G 2391 but there is no rule or law that says he needs to have one. The LABC in fact refused to let my son inspect and test even with a C&G 2391 and insisted I do the testing as I had a degree although in real terms the degree did not show me how to inspect and test all though I did have the 2391 the LABC was unaware I held one.
I think my LABC had a problem in that the inspectors were not trained on electrical systems and they would employ a third party inspector to test and inspect however the hierarchy means they need to employ an inspector with higher qualifications or equal qualifications to the person who is doing the work to have the authority to criticise the work. Otherwise they have a problem which report to accept. Hence why with a degree they decided to accept my report.
What you do need to do is have the correct paper trail. If you have a pile of minor works certificates covering all the work done and no completion and compliance certificate that's OK. But if you have a installation certificate covering the whole job then because it's an installation certificate then you need a completion or compliance certificate as well. Unless at the time it was not a dwelling and then you would need a change of use certificate.
But as to who will ask to see the paperwork is another thing. Insurance company could but unlikely unless something goes wrong. So likely not required until the house is sold. When a house changes occupier then an electrical installation condition report is required and also one should be done every 10 years anyway and in the main this then becomes the proof everything is OK and not the original installation certificate.
So once done if you get an electrical installation condition report you are reasonable safe as this should highlight any faults. It will not find a hidden fault like junction box with screws where it should be maintenance free but one would hope there are no blatant breaking of the rules.
Thanks guys.
Well originally I had intended to have a sparky do the whole job, but I bumped into a neighbor who was a retired sparky who worked on commercial/industrial buildings his whole life. He was involved in the switchgear for these places, and also worked all over the world. I told him what I'd been quoted to do the job and as he wanted to get away from the wife he offered to help for nothing.
So together we drew the wires/cables, starting with the ring circuits, then working on the lights. I snipped old (dead cables as I went along) and pretty much did what he told me to do. In quite a few places we used the old cables as draw wires.
I think the last time he worked before requirement was shortly before 17th edition came out, which did worry me at first, but he seemed to have little trouble knowing what went were.
Over two floors we split each floor. So all the cables go one route to the ground floor, and all the other cables go another route to the first floor. I had the benefit of having a priced quotation from the previous sparky which enabled me to know what to buy, i.e. what fire/smoke to buy, what size cables he intended to buy (sparky knew what to use anyway), most importantly what consumer to buy. I have two PIR lights installed for convenience which were listed, so this made things easier.
In the end we finished up, but my neighbor wasn't confident about fitting the smoke/fire detectors because I confused him as they have wireless functions etc etc, I think he was unsure about all the electronics inside them. So I had the previous sparky who WAS going to do the job to run the cable and fit 2 smoke and 1 fire for £100. He was the one I had a conversation about dead testing/ dead certificate.
So anyway, when he comes to fit the smoke/fire detectors, he inspects the work I've done with the neighbor and says it's all fine and he's happy, we put grommets in the back boxes, run cables horizontal/vertical, clipped, not wedged firm between insulation etc.
So just yesterday (electric meter fitted Friday) I've had a friend of the sparky who fitted the fire/smoke to come out and do a test who apparently had the certification to do it. So he finishes the test which took him 15minutes. This is an electrical installation condition report form KEWTECH, 5 pages, page 1 is details, page 2 looks to be an inspection, page 3 a schedule and page 4, page 5 schedule of test results.
So I've paid £100 for this report, and now have the feeling that I've been ripped off. I was actually under the assumption before he came round that he would notify building control, but he talked me out of that by saying it was not notifiable anyway, and that if they ever ask I am to give the report to them and that would provide assurance of work carried out. He did say it would cost more to send off, but that I could send the report off to BC to get building regulations. Is there any truth in this or have I been stitched up paying for a report that's worthless? I don't actually even no if he's NICEIC registered to do this, for all I know it's a report that anyone could have filled out and gives me no protection whatsoever? How do I know he even did the test?
