S
sparkyspike
So, if I were to disconnect the house from the CU and dead-test the tails and incomers, that's all they need? Sounds odd to me.
Ok. Perhaps this is what the other guy is intending to do.
What if the PIR was carried out before the circuits were disconnected?
In an earlier post pensdown said:In that case I agree with you and I would issue a PIR. At the end of the day, you probably know the certificate procedures better than the person from EDF who requested the wrong one.
But if they insist on an EIC.....
But you're not - when you sign the I&T part of an EIC you are not certifying that the design and construction complies with BS 7671, you are only certifying that the work you did, i.e. the I&T, complies.I would then ask them how I can sign for the design and construction of somebody else's work.
Who would sign for the design and construction then? Would an EIC even be valid without them? I'm not sure it would so i cant see how an EIC can be completed.But you're not - when you sign the I&T part of an EIC you are not certifying that the design and construction complies with BS 7671, you are only certifying that the work you did, i.e. the I&T, complies.I would then ask them how I can sign for the design and construction of somebody else's work.
