Currently replacing a Gainsborough 2000x which would be a 9.5kw(39.9amp) which was installed before i moved in prob when the house was built and worked fine for a few years after i moved in
it was setup in the following way
Separate fusebox(CU) from lights and power (1990's mem), with a single 30amp cartridge fuse,
No rcd,
Pull switch in bathroom(unknown rating)
Wiring is approx 9-10 meters long 6mm+, 2core & earth, via trunking and loft
I went to b&q looking for a 7.5kw(31.5amp) shower
however they only had 8.5kw(35.7amp)+ for sale
i realise i will need to get the CU replaced at some point if the creda 8.5kw i got does not blow the fuse straightaway
Questions
If i fit a 40amp rcd is it going to trip out constantly ?
if i get a 40amp mcb(CU) fitted will i need to replace the wiring with 10mm
thanks guys
No rcd,
Questions
thanks guys
