It's also considered good practice by people who aren't members of any schemesit is considered good practice to do so by many schemes.
ColJack,,
Shouldn't be working live
If you are removing any accessory you should be isolating the circuit
is it me or does everyone else hate the t*****s who wind the earths together
also if the switch has 2 earth terminals then the ring wires must go 1 to each and the back box earth can go to either which ever is easier.
All the wires can go to the same earth terminal.
It makes no odds on a standard domestic circuit.
I always twist them, gives a better chance of a continuous CPC if the screw in the earth terminal comes loose.
Bad practice with single strand conductors, as it increases the chance of fracture.
I'd say that the fly lead is only there to earth the backbox in the event that you crush a wire between the plastic part of the accessory and the back box and not nipping the wire with a screw..
