Yes, but LPG is heavier than air. Hydrogen isn't.
Heat from friction experienced by the escaping gas can be enough to ignite it, but maybe not with the quantities you'd have in a passenger car.I would imagine that what you say about tanks containing liquified gas may be true, provided that there is not a source of ignition around at the moment of rupture and liquid-gas-transition.
The stupid thing about that is that you can take a caravan with an unsecured LPG cylinder connected by a push-fit, perished rubber hose, but not a factory-converted LPG car.Indeed it is, which is why they don't let you take LPG cars through the Channel Tunnel.
Why am I not surprised.The stupid thing about that is that you can take a caravan with an unsecured LPG cylinder connected by a push-fit, perished rubber hose, but not a factory-converted LPG car.
Except that you won't get one. The hydrogen is compressed gas - it has to be cooled to "f**k that's cold" levels before it can be liquified. One of the things they don't mention with hydrogen is the amount of energy that needs to go into it to get it to either a "very high pressure" gas, or a very cold and high pressure liquid. AFAIK road vehicles only use gas, it's not practical to keep it cold enough to store it as liquid.A hydrogen BLEVE might be spectacular.
It shouldn't worry you - at least no more than petrol or diesel. It has risks, and they are different to petrol and diesel, but overall I don't think the risks are higher - just different.LPG would worry me more than hydrogen.
Very quickly, but it would leave things "pretty nippy". At atmospheric pressure it boils off at -40˚ - spill a largish quantity and it'll initially flash boil but will soon cool off and it's boiling rate will be constrained by how quickly it can get heat in. In cold weather I've seen droplets fizzing around inside the gun after refuelling, and done maintenance (replacing a valve) where you draw off what you can, but the pressure is too low to keep pumping it. You take the valve out, and sat in the bottom of the tank is some liquid propane just simmering away at -40˚.LPG wouldalso immediately turn to gas, wouldn't it?
That's an important factor. If there's a spillage, I'd rather it be propane than petrol. The flammable mixture range for petrol is significantly wider than for propane - so if you have a propane spillage there will be a significant period when the mixture is too rich to burn - and it'll disperse quite quickly in any breeze. Spill petrol, and it evaporates much more slowly, and together with it's higher flammability range, you'll have more flammable mixture for longer - and for good measure, the ignition temperature is lower so it can be ignited by things that are too cool to ignite propane.I would imagine that what you say about tanks containing liquified gas may be true, provided that there is not a source of ignition around at the moment of rupture and liquid-gas-transition.
In at least one respect, LPG is safer than petrol or diesel, in that the system can detect leaks, and has a shut-off valve on the tank that operates if excess flow is detected. WIth a petrol engine, if a fuel line is ruptured in a crash the pump will continue to operate until the tank is empty or the power to the pump fails.It shouldn't worry you - at least no more than petrol or diesel. It has risks, and they are different to petrol and diesel, but overall I don't think the risks are higher - just different.LPG would worry me more than hydrogen.
