I want to drop a few 800w and 3kw heaters into a couple of shops to help with the cold weather but the supplied cable is only about 1m/1.5m long, not nearly long enough.
The prospective units are from Costco:
800w - http://www.costco.co.uk/view/p/dimplex-800w-panel-heater-arlwp800ti-159623
3000w - http://www.costco.co.uk/view/p/dimplex-cadiz-eco-3kw-oil-free-radiator-cde3ecc-177536
I want to put the 800w ones on the wall and run a cable down. If it had the length, I'd just put into a socket but I am loathed to run it from an extension.
Can I use a terminal block and some 2.5mm2 heat resistant cable to extend or is there a better way ? If a terminal block is ok, can I just tape it with insulation tape ?
I was considering trunking it down the walls but if I use a terminal block I am not sure it will fit into the trunking (unless I get a bigger size).
I guess I could run a spur from a socket and hard wire directly but again, without disconnecting the wire from within the appliance to run longer cable, I would still have to extend somehow.
Any help appreciated.
