D
dan2071
Hello, I have been brought in by a joiner to pipe up a kitchen in a church.
At the moment they have two sinks next to each other with cold taps on both.
( Sink Waste is in 42mm Copper! Cant wait! )
They have requested a hot tap, the only way they can have a hot tap is if i install an Electric Water Heater, I have thought about it and a store of water is impractical because they might only use it once a week.
I was thinking about fitting a Santon HP924 which is a 9KW Instantaneous Water Heater. I was wondering what sort of flow rates etc i should be expecting?
I know with this heater, i can run a 15mm feed to a tap, but i was wondering what the out come would be if i took it into a mixer tap? Would the cold water over whelm it?
Thanks, Dan
Thanks, Dan
