My other half has just bought a small kiln for doing ceramics and the like. The kiln is specifically aimed at the hobby end of the market so it's single phase, 13a and 3kw with a standard 3 pin plug in terms of the spec.
We have an old (ish) house but have a new consumer unit and have had the garage (where the kiln will go) rewired about a year ago. The garage has a feed from a spur/junction box on the circuit for the back of the house which has its own breaker on the consumer unit. The garage also has a 13a fuse box on the electric supply.
If the kiln is drawing close to 13a all the time that it's on, how does this play with other things on the same circuit? I always thought the total for each circuit couldn't exceed 13a. So what if the kiln is running and there are other things on? Or is it a case that each outlet has a maximum rating of 13a? There must be a limit to the number of amps that each circuit will take. Just off the top of my head, that circuit has the washing machine, tumble dryer, a fridge, a freezer and a few other appliances. Plus the kiln. What if they're all on at the same time?
I just want to make sure that we're all safe before we fire this thing up!
