At the moment I have an old mechanical pound coin meter that I use for secondary billing. It's limited as it can only hold about 7 days worth of electric (80kwh).
I was going to buy a new secondary meter that had pulse output and rig it to an electronic coin meter that I would make.
Don't worry the secondary meter would be hooked up by a (qualified) electrician - I'm just going to mess about with the pulse output it produces. (safe and legal right?).
I noticed that the existing meter already had pulse output - sadly I think to get access to the terminals of the pulse output (1000 pulses per kwh) you have to break the seal.
Would the electric board (british gas) let you make use of this output if you contacted them? Can an electrician break the seal for you and attach the wires and re-seal the main meter?
Thanks.
edit:
Or does anyone know of any non-intrusive way of monitoring kwh. I already have those meters that clap around the live wire, im not sure of its accuracy. Plus it does not have pulse output - I would need that to link to a coin meter, my electronics knowledge would only stretch that far. It would be hard for me to open the unit up and try to get the kwh info from the unit.
Thanks.
edit:
