Fair enough. I presume that you checked that there was not a second one on the side of the cylinder (usually near the bottom)?On top of the HW cylinder tank is a Sadia 3Kw immersion heater, but this is not wired to anything up so is redundant!
I look forward to seeing the readings. Something here 'does not add up'. If your fridge and freezer really were using as much electricity as your figures have suggested in just 4-5 hours at night, over a 24h period they alone would be using far more than your total electricity consumption!The chest freezer in my outhouse which is quite large and only 1/4 full with a dodgy door seal from probably being outside may point to the consumption overnight? Can't think it being anything else? I will check my readings on both tariffs before bed and again in the morning.
Kind Regards, John
