Electric plinth heater under sink??
Thanks all. In answer to the questions:
Not sure what rating the hob is. It's a 4-heater induction hob, and the electrician is putting it on its own circuit).
It's a good idea to try it first under the larder unit - I'm assuming that it wouldn't work there, but it might. I'll do that.
As regards putting it under a 400mm unit and removing some legs: I did think of that, but one 400mm unit is at the end of a run and adjacent only to the WM; another is between the DW and the fridge; and the other is next to the sink but nothing else. The only reason I've got the 400mm units is because I wanted a standard base unit next to the DW and WM so I had somewhere relatively accessible to plug them in. The electrician was happy to use a standard single socket mounted on the inside of a 400mm unit, but I've asked for fused switches above the worktop, to operate an unswitched socket in the 400mm unit below.
