I can't help him if he cannot help us....Thats not the OPs fuseboard, thats a picture linked from wikipedia....
We need a picture of the ACTUAL things involved..
Is that true?The re-wire-able fuse today is not permitted when the installation is in the charge of an ordinary person, it has to be a cartridge fuse or MCB because it is so hard to be sure the wire used is the correct size, but cartridge fuses are expensive.
Does that mean it cannot be done?An electrician will have a clamp on meter and can easy test what power the shower is using, so he will know if fault is shower selection or faulty fuse wire, but then the next problem is although there is nothing to say you can't continue to use the existing consumer unit, nothing new can now be added and comply with regulations.
It should say "the circuit must be RCD protected", therefore a new shower may be fitted if the circuit is not being altered.I have not seen a shower in years which does not say must be RCD protected, so if wrong shower then unlikely a new one can be officially fitted powered from that fuse box,
Is that true?so likely your looking at changing the fuse box for a type tested distribution unit called a consumer unit,
True, but if one can find the relevant small print, one discovers that the power consumption of these things are nearly always quoted at 240V, in which case the current drawn by a "8.5 kW" shower at 230V would be roughly ..
8500 / 240 x (230 / 240) = 33.94 A
... but still over 30A. However, although slightly over 30A, that current should not blow a 30A fuse (if that is what we are talking about) - although, as you suggest, it could reduce the lifespan of the fuse.
Kind Regards, John
I wondered that, and suspect that it probably isn't (true). I also wondered whether it is really true that it is appreciably harder "... to be sure the [fuse] wire used is the correct size" that it is "... to be sure that a cartridge fuse of the correct rating has been used".Is that true? [the first one!]
As I (and others) keep telling you, for better or for worse, and silly though it may be, the regs require one to calculate what the current would be at 230V, not what the current actually will be with the supply voltage the installation has.And a lot over that if his supply is around 245v as most are.
As I also recently wrote, one would expect that sensible safety-related regs would require the calculation be be undertaken at 253V - not 230V, 240V, 245V or any other figure ... but they don't.
Kind Regards, John
You know that, and I know that, and I'm pretty sure that most/all of the authors of BS7671 will also know it.That may be so but the fuse does not know that.
That would seem to be a logical conclusion - unless I've missed it, I don't think that the OP has yet told us whether the fuse blows immediately on switch-on of the shower (which it obviously would with a ';short circuit'), or what.Surely the problem must be a short-circuit; the shower can't draw the 55+A required to blow the fuse - eventually.
...How soon does the fuse blow after you turn on the shower?
Do any other sockets or appliances stop working when it blows...?
Some of the old Wylex fuse boxes can take a larger fuse with first fuse carrier only, I don't know what part numbers change there is between the two types, I can only tell once the fuse carrier base is removed, however it would also likely require a heavier cable and that would be a major problem.
