What would give the better shower an 8.5kw electric shower. Or a bath/shower mixer tap ran off a combi.
Electric showers are last resort, only fit when that's all that's possible, or for people who only want to spend the minimum possible and won't be using it themselves.
I installed mine and I have used it most days for the past 50 years, though now the third iteration of electric shower. Why would anyone not want to use one, they work just fine, especially the more recent higher powered/better controlled models?
Before that I had a large instant gas heater and mixer. Higher rate of flow, but took a good while before it settled to temperature. My electric settles within 5 seconds.
So you have a combi or unvented so could have a mixer shower etc. But you have chosen electric?
Mixer to run off the combi every time unless you can have a shower under a dribble ( from electric shower) when the weather gets Baltic. Even the smallest combi will be nearly like a shower from nearly three combined electric showersWhat would give the better shower an 8.5kw electric shower. Or a bath/shower mixer tap ran off a combi.
The incoming public water supply is never 'Baltic', normal variation is around 5C winter to summer. My shower, even now at the coldest part of the year, with incoming water temperature at a minimum, cannot be described as a dribble - it is far from. The exception was one morning last week, when the water pressure was a little lower than normal, but that would also affect a combi mixer too. We occasionally suffer a dip in pressure, quite randomly for a day - which I have never been able to determine the cause of, likewise out supplier. Their best guess has been local farmers spraying lots of water on their fields - but at this time of year?
granted, 8.5kw against 24kw is no contest.
When commissioning boilers for benchmark, I use clamp thermometers so can record incoming cold and hot delivered water temperature. 5- 17 degrees is not unusual winter- summer for cold water.
