Electric Shower Recommendation
Is your hot water system, an open vented system, or a combi boile
You say 2 storey townhouse, do you mean 3 storey??
A 2 storey property shouldn't have issues for water pressure on the first floor.
If you are confident and competent enough, you can always buy a new electric shower try it. If problem persists then it's definitely water pressure issue.
My bad, sorry 3 storey townhouse.
Is there an electric shower brand/model you recommend?
Are you sure there's no leaks in the incoming water supply to the property? Years ago had this issue, swapped shower and same issue. The problem was a lead incoming pipe that had a small leak and the pressure dropped by the time it got to the shower in first floor.
Remember it doesn't have to be a huge leak even a minute leak would be sufficient for the shower pressure to drop from the minimum required.
We did have a small leak a few years ago but resolved it.
I have a Mira Sport 9KW which is brilliant. It has a summer and winter setting depending on the incoming water temperature. My plumber fitted a filter in the incoming pipework which lasts 10 years and stops it furring up with limescale.
We have issues with poor water pressure and fitted two Mira Magnaflo mixer showers, fed from the combi. One replaced an electric shower and the other an old Aqualisa mixer.
It was a great improvement.
As someone stated speak to a plumber. Better still, get a water pressure test. My money is still on a leak. There might be a leak in a shared / mains / incoming supply even on the street. It doesn't have to be big leak but clearly it's enough affecting minimum pressure. Or you might want to have the pressure increased
For what it's worth, I've never fully been able to understand the hate directed towards electric showers.
They do seem to be a naff solution to a problem and I certainly agree that a combi-fed thermostatic shower is unquestionably better, but they do have their place.
My current house we are just about to vacate has two showers - an electric in the main bathroom and a thermostatic shower in the ensuite running from the combi.
The shower has been in since 2016 when the house was built as we specified it as an optional upgrade when we bought the house.
It's a Mira Galena same power rating as this one here: https://www.screwfix.com/p/mira-galena-slate-9-8kw-manual-electric-shower/9461g
I honestly cannot fault it. It's completely unaffected by other people in the house running taps or flushing toilets, or the washing machine using water. The pressure is fantastic.
Obviously, it is not cheap, but then perhaps electric showers are a case of 'you get what you pay for'.
Whenever I see forum posts with people complaining their electric shower is c@rp, it is always a very low end affair at an almost disposable price while simultaneously looking like it's come straight out of the mid 90's.
The main issue seems to be lower pressure than a conventional shower, but I've only really seen that when we have a heatwave which goes on for a few days and the incoming supply to the house gets warm. Even today, when it's 20 degrees outside, the pressure at my shower is excellent.
Have checked with a pressure gauge.
Good news is I get 2 bar on the ground floor and 1.8 - 1.5 on the top floor where my current electric shower is. With another tap on it drops to 1 bar. Should be fine for electric shower operation I think.
