crafty1289 said:The immerison heater will only work at night. many have a top-up heater in the top of the hot water cylinder, which is connected to the normal supply. dont know about the heater you describe though.
so this means the main immersion (3kW) will be powered from the cheap meter on a 16amp dp mcb
and the top immersion (3kW) is to be powered from the main cu with a 16amp dp mcb?
