Hi there,
I have constructed a storage shed to which I have run a 25 metre 2.5mm 3 core SWA cable underground.
I want to install one double socket and two 58W fluorescent strip lights.
The SWA cable comes from a 16A MCB in the RCD protected side of my Consumer Unit. I have a TNS supply (I'm pretty sure) it's definitely not a TT supply.
I want to terminate the SWA cable in a metal clad double socket using the third core as an earth and take the supply for the lights from there.
My problem is how to protect the light circuit if at all.
Can I feed a fused spur from the double socket that I install a 6A fuse in - or will I need to install a 6A MCB somehow - with a small enclosure?
Can I feed the 58W strips with 2.5mm twin and earth directly from the socket via a light switch? (pretty sure I can't do this).
Hope you can help - thanks in advance.
