It is he who needs to change for it is he who is educating ineffectively
It's not a question of behaving correctly or incorrectly. It is a question of whether it matters to you whether or not you are communicating your (often important) points as effectively as possible - and it seems that this matters to you less than some concept of 'behaving correctly'. IMO, it is a great pity, given your potential.It is crystal clear. It is not I who needs to change for it is not I who is behaving incorrectly.
Of course it is - it cannot be otherwise.It's not a question of behaving correctly or incorrectly.
It's your decision. If you regard that as more important than effectively communicating about matters relating to safety, then fair enough.Of course it is - it cannot be otherwise.It's not a question of behaving correctly or incorrectly.
I don't think the matter under discussion has got anything to do with syndromes or diagnoses - it's simply a matter of the way he chooses to prioritise different considerations (which is for him to decide), and he seems to have made his position clear.Not sure why we still bother trying to communicate with b-a-s; we're not going to get through. ... And we know what happened when we inadvertently strayed down the road of remote syndrome-diagnosis, so I'm sure nobody wants to revisit that.
It's a bulleted list. What style would you have me adopt as an alternative?Many of us are therefore rather saddened by the fact that you so often adopt methods, 'styles' and 'positions' which, even if you don't accept it (or care about it, since you blame the 'recipient'), are often almost certainly counter-productive in terms of what you are trying/hoping/wanting to achieve.
Do you want to defend that position?Unless you want to defend the position of people undertaking electrical design and construction without actually knowing what they are doing, I think you'll find that there is no alternative to putting the effort in to learn.
does not indicate that you read this:a 'reading list' of a dozen or so books and other items, one or two or which appear to relate to the '16th edition' but, as far as I can make out, none are directly related to the '17th edition'.
If you want to make yourself look like an idiot, don't hold back on my account.And we know what happened when we inadvertently strayed down the road of remote syndrome-diagnosis, so I'm sure nobody wants to revisit that.
There is too much to write to explain everything necessary and/or required for outdoor installations.
It would need a step by step instruction manual.
If anyone wants to write the 'War and Peace' for this then carry on.
Until then, employing an electrician to, at least, supervise is the only answer.
Yes, maybe you should consider that approach or, at least, a diplomatic variant thereof. As you say, if one just bluntly says "get an electrician", it may well not be well received.Still - maybe I should consider this approach:i.e. stop giving people information to help them acquire competence and simply say "get an electrician"? ... I have to say though, that approach has not been well received in the past.There is too much to write to explain everything necessary and/or required for outdoor installations.
It would need a step by step instruction manual. If anyone wants to write the 'War and Peace' for this then carry on. Until then, employing an electrician to, at least, supervise is the only answer.
Have a look to see how many times I have said "Asking questions here can be a useful part of a learning process, but they are not a substitute for proper structured studying. The key term there is "learning process" - you cannot learn all the things you need to know just by asking questions here. It isn't structured enough - it won't provide you with a way to progress where each step builds on what you learned before.""I think you would be best advised to employ an electrician, because there are so many things you would have to learn regarding issues concerning outdoor electrical installations before you could do this work safely and competently, and we can't possibly give you all that knowledge by answering questions in an internet forum."
But I absolutely do not believe that the time and effort is not justified - it is learning, it is growing, it is acquiring a new skill."If you wanted, I could guide you as regards suitable reading material etc., but I really do doubt that the time and effort of all that study and learning would be justified to enable you to do what may well be just a once-in-a-lifetime job".
As BAS pointed out early on, there is confusion/uncertainty from the OP as to whether or not we really are talking about separate temporary and permanent arrangements (my emphasis) ...Back to the original question, if it were me I'd go with the 100m of arctic cable as suggested earlier. For the temporary connection that is. ... For the final connection, will that be a DIY job as well? If so, then ...
I plan on running electricity out to the shed so I can run my power tools whilst building it. And to use once built. Would it be ok 2 link several 13A garden extension leads together ...
