I would say most of us are guided by the organisations,
and they seem to think even an old fuse box is still able to give more service. As to C3 code it is not a code 4, if the C3 was to contain all that was in code 4 then there would be no point in ever removing it.
The government may say BS 7671:2018 but BS 7671:2018 says you only use it for designs after a set date, so it is following BS 7671:2018 if for an installation designed in 2009 you follow the requirements for BS 7671:2008, however for an installation designed in 2019 then it must follow BS 7671:2018 and the government saying BS 7671:2018 insures you use the version current at the time of design, but does not require you to follow anything asked for in the future. However this is more a subject for the English student than the electrician, it tests your ability to read and comprehend, not any electrical ability. As to Wales there is a problem, to be legal in Wales there must be a Welsh version, and there is not as yet a Welsh version of BS 7671. Even if one was produced it would be a translation, and we have seen the mistakes many times when even road signs are translated.
There is a common phrase "Let the courts decide" and it will require court cases to clarify new laws as always.
But when an inspector does an EICR he does it to inform, he has no special powers, or any special qualifications, or requirement to be a member of any schemes or other organisations, it is down to the owner to select an inspector who complies with the laws requirements, with the insurance and qualifications, not down to the electrician or other to refuse to do an EICR unless he has them. The same with Part P, with a proviso, if the electrician advertises he is a member of a scheme then he is breaking the law if he is not, but he can do work in any factory, shop, railway premises, or domestic the only thing is, unless a scheme member the owner of domestic premises would need to inform the LABC first and pay their fees.
The point I am making is it is down to the owner, not the electrician to ensure the person he employs has the insurance, qualifications, membership, and any thing else required, and it is the owner or his representative who has to take the exam to show he knows what is required and is looking after his tenants.
So as electricians we must ask our selves what happens if we get it wrong?
We have all read the
the report on the Death of Emma Shaw and I will be frank it was not the result I expected, so it is hard to know what a court will say. But the big question, be it C1, C2, C3 or F1 if the electrician has highlighted a danger has he really failed in his duty?
I have said before, I considered my mother with alzheimer's and my 14 year old son with an amateur radio licence to be at risk, but my father-in-law, and son-in-law are not at risk, as father-in-law knew enough to keep himself safe and son-in-law would not dream of playing with anything mains powered. At work either a guy is trained, or not allowed to touch 230 volt, so at work the problems are a lot less than in the home. Even in public places children or others with reduced awareness are not left unattended.
The home is rather unusual in that people will do daft things, like my mother putting an extension lead in a bucket of water, and for the owner occupier you know the risks, but the landlord does not know the risks, neither does the electrician doing the inspection, and I personally would not want to rent out any property without RCD protection, however that does not mean no RCD is a code C2.
So if we assume any fault or non compliance is give a code, what is the risk to the electrician if he gives a code which is wrong? Clearly with exposed live parts, he should not leave it still with live parts, either corrected or isolated. But what about a missing or a blank that can be removed without a tool on a consumer unit? Let us say the consumer unit is under the stairs, and a toddlers goes under the stairs and plays with it and removes the blank and gets a fatal shock, so what code would the electrician have needed to have given to not get a custodial sentence, and what code or action not to get a fine. Lets face it this is an electricians worse nightmare, I really hope it never happens, but it could, and we want to have done the right thing.
So is a consumer unit with a plastic blank which can be removed without a tool C1, C2 or C3? the space left is over 12.5 mm so clearly not compliant and has not been compliant as far back as I can remember, so likely who ever fitted the plastic blank would be guilty, but what about an electrician who did the EICR, if he has given it a C3 is he also guilty? It has likely been like that for many years, so why should it need urgent repairs? But even with a C2 it is not cut and dried, however the bus bar was not actually exposed so could hardly be a C1. I would have likely given it a C3 although with some thought maybe it should be a C2, but the same thing in commercial premises would never likely cause a problem, and there is no difference to an EICR in commercial to domestic. Or is there?
So big question if a C3 is given instead of a C2 what legal difference does this make to the electrician giving the code?
