I thought I'd get round that by asking what are the FOUR primary colours, the arguement was even worse until I shone red, green and blue lights on the ceilingDon't talk to me about pub quizzes.
I am still in a rage for 'apparently' getting this question wrong 20 years ago:
'What are the three primary colours?'
I said red, blue, green.
The answer they wanted was red, yellow, blue.
The difference between physics and art.
Ah yes but...So to "In a standard UK plug mains plug, what colour is the Neutral wire?" the answer is any colour other than green. If the equipment is imported then it could well be white and the line is black.
Even with UK equipment it is common for line 2 to be blue, and line 1 brown, where there is no neutral as with 110 volt equipment. Yes we were all taught red to red, yellow to yellow and blue to bits. And yes some times you do look at blue and black wires and think is this a phase or neutral, and maybe it would have been better to have used white for neutral same as USA.
NO. NOT Anti- / Post- Meridian [a line of longitude] BUT Ante- / Post- Meridiem [Latin for 'Middle of Day' {meri diem'}, taken by some to mean when the sun is at it highest].Anti- Meridian = am (before)
Post- Meridian = pm (after)
Concerning sun-dials, have you ever considered why "clockwise" is the direction which it is?This is why I blame the railways, before the railway and time tables each town could have a slightly different time likely set with a sun dial which would likely be correct.
So do sun dials move anti clock wise in southern hemisphere? That would mean they would not work on in the tropics as they were reverse direction summer and winter, but I think they do work. Like the direction of water down a plug hole, it does not really change.Concerning sun-dials, have you ever considered why "clockwise" is the direction which it is?
It is because that is the direction the shadow of the gnomon on the Sun-dial moves - in the Northern Hemisphere - where both Sun-dials and clocks were invented.
Seriously? Picture a globe in front of you with a pin sticking upwards on the top, and the globe is rotaing anticlockwise (because that defines the north pole as being on top). Now image a lamp off to the side (the sun). Now imagine which way round the shadow will rotate around the pin. (Obviously clockwise).So do sun dials move anti clock wise in southern hemisphere? That would mean they would not work on in the tropics as they were reverse direction summer and winter, but I think they do work. Like the direction of water down a plug hole, it does not really change.
Inevitably.So do sun dials move anti clock wise in southern hemisphere?
They will 'work', at least in some senses, even at the equator. Although the shadow will then always follow a straight line East-West path (rather than 'rotate'), the length of the shadow will vary with the time of day (being of zero length when the sun is directly overhead, at 'midday'). The further you get from the equator (even within the tropics), the more of a 'rotational' component of the shadow path will appear, but I'm not sure how far one has to get from the equator before the angle of rotation (rather than just the length of the shadow) become 'useable'.That would mean they would not work on in the tropics as they were reverse direction summer and winter, but I think they do work.
By the way, returning to your comments about trains and timetables, I think that mechanical clocks were developed, largely as an aid to maritime navigation, centuries before trains - so you probably should be 'blaming' ships, rather than trains
I don't think that is conceptually essential - one can 'tell the time' from the shadow of a simple vertical pin.The gnomon (new word learned) has to be parallel to the Earth's axis, i.e. tilted at the location's latitude toward the relevant pole.
Indeed - I presume you mean 'curved' in the up/down plane - i.e. one would have to have the gnomon (or pin) in the middle of something like a soup bowl, in order to avoid those very long shadows early and late in the day.Therefore at the equator it has to be horizontal with a curved scale beneath (otherwise the nearer sunrise and sunset the shadow will be a long way away).
All true - but I thought (maybe wrongly) that eric was blaming train timetables for the development of timepieces!There was no need for ships to have the same time in Penzance and London. All they needed was an accurate clock to tell them the time in London, then they could work out there longitude
That would vary throughout the year except at midday.I don't think that is conceptually essential - one can 'tell the time' from the shadow of a simple vertical pin.
Yes but just a part of the soup bowl.Indeed - I presume you mean 'curved' in the up/down plane - i.e. one would have to have the gnomon (or pin) in the middle of something like a soup bowl, in order to avoid those very long shadows early and late in the day.
