Electrics Advice (Outside)
No... your instructions say 30 milli-amp RCD! Get the electrician in to do it and then you can concentrate on the fish!
Would i still need permission with this method
Yes
would this work any advice how i would connect up to consumer unit
If a new circuit use (2.5mm or 4mm) swa from cu, using 20amp or 32amp mcb.
Use correct glands on swa & terminate correctly.
To be honest it will end up being just as well to use a sparks if you cant terminate swa or are unsure how to connect to cu.
Anyway gotta go now.
