If absolutely everything is disconnected with Live and Neutral disconnected and then switching the electric fire on causes the RCD to trip then the fault is 99% sure to be a Neutral to Earh fault in the wiring. As mentioned switching off an MCB does NOT isolate the Neutral on that circuit.
One fault often over looked is a damaged or saturated outside light with a Neutral - Earth fault.
It would be quicker to get an electrician to do the insulation tests
