Its down to what the cable can take.
One twin socket = one 3kw fire plus lamp, second one could be plugged in the same, too much load on the cable(?), it's not the way to do things these days.
I personally, if possible, when running one cable into the loft would run two and extend the ring main, if you're going to chase the wall for one cable an extra 3/4" of plaster over the second is no hardship and then you can add as many sockets as you want (theoretically).The way I did it was to find a convenient double ring main socket, remove one set of wires, go into the loft, come back down and added another twin socket next to the original I broke away from, connected to this and reconnected the old ring main to the new socket. Reason being, a socket is not much more than a junction box and at least you can use it for something (hair drier, curling tongs, whatever turns you on) !!
