ollski said:Yep a flat expansion vessel has probably caused it to open the pressure relief valve, problem is these come with all the return pipework and cost about 110 quid although all you do then is unscrew the 2 grub screws and use 10 quids worth of valve. Although if you try this site they may well help you.
http://www.europeanspares.com
search leblanc then pressure relief and you may be lucky...it will show the grub screw one for the gvm 4.20 and the screw in one for the 5.20 though the last time I ordered the 5.20 they told me it was the last one and they didn't think they could source any more....but worth a try.
Just re-read the posts here!
Could a flat expansion vessel be the cause of my problem? If so, would I be able to re-pressurise it myself?
Could someone give me a few tips on this?
Many thanks in advance,
Mark.
