HI all, I am trying to connect a additional sounder to my alarm system. i will give you a quick brief of my alarm system, I have a scantronic 9600 with 2 bells, 2 keypads,1 speech and text dialller,1 internal sounder, 4 pirs, 2 door contacts, 1 panic button, 1 smoke detector and 1 carbon monoxide detector. 9 zones in total. I also have a 12v 2 amp elmdene power supply.
So I would like to add an extra sounder to the system for the extra punch. I have bought a lyntech 120db horn which is extremely loud which you can hear a mile away, however on a current test this draws 1 amp according to meter. The sounders currently on the system are a prima 300 (front) and a prima 500 (back) these are fed by the 2 amp elmdene psu.
when I installed the sounders I checked the current draw for both sounders in alarm seperately. the prima 300 drew 535ma but bearing in mind this could of been because its onboard internal batteries were not fully charged. it could be less now as the batteries are fully charged I have not checked the current draw since, and finally the prima 500 draws 250ma.
So either way the additional horn will need to be powered by the elmdene psu.
The main control panel supplies the keypads, pirs, speech dialler, internal sounder,
and the bell, strobe and tamper relays (the relays draw 60ma each).
The elmdene 2 amp power supply (next to the panel) feeds the bellboxes.
The total current from the panel in alarm is 668ma and the total current from the power supply at a guess is 785ma, 1285ma if include the 500ma battery charging current.
so when I connect the horn the total current is going to reach 2285ma which will probably overload the power supply. 1785ma if I take away the 500ma charging current in which case the psu will be fine. there are 2 fuses on the psu one for the load and one for the battery.
so finally here comes the questions,
1. when calculating the total load on the psu should I include the charging current?
2. will I overload the power supply?
3. if the answer to question 2 is yes. should i power 1 sounder (prima 300) from the panel?. (the main panel is rated at 1250ma if i add the prima 300 to the panel the current will be more or less near the the max. while the panel will most probably handle it I do not want to push my luck.
4. should I upgrade the 2amp psu to 3amps.
thanks
thanks
