The Op had soldered a pipe in one end, look at post #7
Then there is no need to ask if he can do something that he has already done. He surely knows the answer already.The Op had soldered a pipe in one end, look at post #7
Presolder where you can; hoover up the shavings, damp down with a plant spray bottle, have a wet towel to hand.
Have fun! And spray your scorched areas again and check when you're done.
Cut the pipes either side of the tee, move the tee and pipe stubs and solder it up including the piece going through the wall. Put back in place and reconnect the pipe stubs to the rest of the system with straight connectors. Looks as if you'll have enough movement to avoid needing slip couplers.
Don't leave those copper pipes laying directly on the hardcore/concrete. Put them in pipe insulation/conduit (like the plastic ones to the right)
You'll be at risk of erosion from thermal cycling if you do.
