We're selling mums bungalow and so needed an EPS. It's a small property built in 1980 and each of its 5 heated rooms have a dedicated room thermostat and a 2 port motorised valve to control the radiators therein.
When we received the EPS, the assessor wrote that improvements could be made by installing Thermostatic Radiator Valves. I fail to see how this can make any improvement, especially as each room also has its own boiler interlock through the motorised valve, which standard TRV's don't, and properly located electronic thermostats may even be more accurate than mechanical TRV's positioned in the corners of the room right next to the radiators.
So, I believe the assessor is in error, but before I raise this with him, have I missed something? would there be a fuel saving by taking them out and installing TRV's in their place?
If anyone is curious as to why this system was installed, when the property was built, the room thermostat was located in an internal passage without a radiator, so if the doors to the rest of the property were closed, it didn't sense any change to the temperature and the heating would stay either permanently on, or permanently off.
