- Joined
- 27 Jan 2008
- Messages
- 24,691
- Reaction score
- 2,830
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Talk about two way switching and we all think of the double switch arrangement where two switches both control the same lamp. However I would consider two way to be on and off. i.e. one way is on the other is off.
Moving on we have three way switching where for example a PIR is used so centre off with one way to switch on lamp at all times the other to set control through the PIR. Or is it? Others refer to three way as adding an intermediate switch so three switches control the same lamp.
However the intermediate switch system could have 10 switches controlling the same light hardly what one would call three way.
So how should one refer to a system with two change over switches and an intermediate without there being a possibility of being misunderstood?
I can see using two switches as being two way as the switch is called a two way switch which of course is correct it can send power in one of two ways. But some how three way switching just seems wrong for an intermediate switch system. The switch has only two ways not three so why call it three way?
