That's actually my point - the terminology used should really describe the funtionality, not the number of switches. One other functional possibility which I 'had in mind' was a master ('on/off') switch in series with a standard "2-way" switching circuit - still three switches (hence "3-way switching" per your terminology?), but different functionality.
But that's not what I understand as three- (or any number) way switching.
I'm not sure what that would be called, other than describing it as you have.
Also, you include in the description, "2-way switching", which, I think, verifies my point.
It's only understandable to me because I have learned that this is well-established electrician's jargon. Were that not the case, I would probably have assumed that "2-way switching" referred to a 2-way switch which diverted power to one of two alternative loads - just as a 2-way or 3-way fluid or gas valve diverts fluid or gas in one of 2 or 3 directions.
But we are talking electrics and that is what it means.
As above, "2-way switching" is only understandable to me because I have learned that it is well-estanblished jargon. I haven't (yet!) learned that the same is true of "3-way switching", so I wouldn't be sure what it was meant to mean.
True, but there is not the same scope for confusion, then. I know what I normally understand by "3-way switch", so it's very tempting to assume that "3-way switching" is related to that.
Not if you agree with what two-way switching means.
I agree - but until this thread appeared, I for one would not have been at all sure what "3-way switching" meant. I probably would have guessed correctly (by extrapolation from "2-way switching"),
Precisely.
If, as in this context, 'way' means, as you, yourself, said, position, as in place or location, then is it not apparent?
That is, amongst electricians.
Obviously, were it overheard in a pub, you may not know what was meant.
but guesswork is not quite the same thing (or as desirable a thing) as 'understanding'!
No, but what do you do about other terms of which you are not sure.
