Any idea of the make/model of the pan.
Cracked pan, or maybe a pan connector problem, need to know type
You did say the smell goes if you cover the pan with clingfilm.
Nope, smell percolates up the cistern overflow pipe and then into the ensuiteDoes it go if you cling film the pan only.
No bubbles but the level drops by a few milimeters in ensuite loo before the AAV kicks in and level returns back to normal. At no point does the level go low enough to affect the trap thoughIf you flush the main bathroom toilet, does the level change or bubbles appear in the ensuite toilet?
yep doitall is spot on
i would also like to add that sometimes that airflow may cause smells to appear well away from source
so sometimes you need to stop using incase the smell is peculating from another area
If you do a Heath Robinson job with some tumble dryer hose and duct tape - you will be able to seal round the pipe and the window - and do a test for several days just watch the duct tape residue. You don`t necessarily need to go through the roof to vent - you can go through the wall and up the outside - if it`s unobtrusive . I just don`t like AAv`s because they only deal with neg pressure - Drains are subject to positive pressures too -It`s the aav - if the pipe was vented to open air it would work
This was my next thought but I want to be sure that is it before going putting a whole in my roof. As we don't use the main bathroom very often, I wonder could I test the idea by venting into the bathroom with the window open (window is right beside the loo and AAV). I know it won't be the same as venting to the outside but could it work??
