Hi guys,
Some advice please. 3 months ago i finished the wiring for 60 bathrooms for a housing association, i was sub contracted. I ran 10mm t and e for new shower with isolator on a 40A rcbo. came of lighting circuit for timed extractor and fused spur for low voltage wet room shower drain pump. The incoming water supply for the buiding (on three floors) came over head through top lofts, in 25mm mdpe in each flat. I bonded in 10mm at the point it changed to copper and because the hot water and central heating came in from a common boiler, i bonded to these services too and back to the individual mets. All connections are accessible behind a service hatch built into the 'shower wall' boarding. For certification i tested continuity of bonding and completed certificates.
Now someone has done a continuity test from copper pipe work entering cold water tap to met and there is no continuity. This is because after a word with the plumbers there are some inaccessible plastic push fit plumbing connections.
The housing association want me to go back and bridge these!!!. Advice please.
Surely, the copper now holds no earth potential and if it does touch the hot or heating flow or return i have bonded these.
Ben.
Ben.
