- Joined
- 13 Jan 2025
- Messages
- 15
- Reaction score
- 3
- Country
Morning All,
I've purchased a new builder and have ESI thermostats upstairs and downstairs which are mains wired. 5V I believe.
I was planning to install the Tado thermostats myself by messing around with the wiring center but would require the chopping of cables. Before I did this I checked the wiring behind the thermostats and have discovered these are CAT5 data cables which halted my progress and I'm not getting an electrician to do it. Although he's never done thermostats before he said so wasn't 100% sure but was going away to do some research.
Anyway, he has come back to me and said he is going to need to run new wires as the cables that have been installed by the builder are CAT5 data cables which cannot run over 240V. Obviously I don't want new wires run as this would mean cutting out channels etc in the newly built house which the wife will not want.
Someone in a similar position to me but with the correct wiring behind the thermostats has suggested using a Shelly 1 Plus relay as a workaround and mentioned it needs to be a dry contact relay so 240V are not going down data cables as that would obviously be a fire waiting to happen.
Would anyone know anything about that as the electrician didn't really take me on when I mentioned it? Or is my only option to run new cables as suggested?
I've added pictures of the wiring and wiring center for reference.
Cheers
Cheers
