I am planning to wire phone/broadband and ethernet throughout the house. That means 7 ethernet and 8 phone points (1 master).
What I am getting is cat-6a cable for ethernet and cat-5 for the phone as well as relevant connectors. Each socket will have both ethernet and phone snap-in connector within the same socket.
For ethernet, there will be a central patch panel in a small utility room which will connect to a switch/adsl modem. Cables will go off the patch panel into the walls to individual room sockets.
For phone line I am less certain I know what I am doing. I wanted to re-use the same cable runs as ethernet to save on planning/drilling separate runs so no daisy chaining. The way I was planning it is to have a master socket with ADSL modem next to ethernet patch panel and then from the master socket a junction box which will distribute signal to all other sockets connected to it.
I was planning to run cables away from electrical wires (min 15cm) but together reusing the same cable runs. Both cables are shielded.
Am I on the right track here or have I missed anything?
