Euro 46 issue setting alarm with tag
Ok so its trying to set all 4 areas simultaneously. U will either need to use flexi set on the tag or program it for desired area only. Do u know the area setup ?
Or you can enable level set (depending on how your areas are programmed) and leave tag as it is, and it will set the default area for the keypad.
I know the areas that have been setup against each button. The A is a full set which is what I use to arm the alarm when I leave the house. I am wondering if the level set has not been programmed to the tags
U need to enable flexi set on the tag. The procedure will be present tag, select area, press yes, leave via exit route.
