Eurosec CP8L " Call engineer " Message keeps being displayed
15 Feb 2017
Hi There
i'm a newbie here so apologies if this is the wrong thread. I had an alarm system installed 7 years ago when I built my house. I cannot find the local alarm company - must be out of business. My alarm went off at 3 am one night and I cut power to it as the key fobs or code did not work. After trial and error I discovered a battery error.
I have had to replace the large battery for my alarm system (Yucel) and done a test. Everything seems ok. But my Eurosec CP8L panel keeps showing me "call engineer" when I try to set entry and exit codes with the fob/code . Do I need an engineer code to remove this? If so where can I get one?
Ideally I just want to use the fobs to enter exit and set a part code to disable upstairs PIRs at night. I have downloaded the manual.
Any advice would be really helpful.
Your duplicate has been removed.
Moderator
Not a cpl with fobs ! It's probably a CPX panel same as gardtec 490 panel it may have been programmed for engineer reset , or even worse engineer locked
It needs defaulting to find out ..
Worse case new pcb
Thanks sparkymarks. I think your right it looks same as the gardtec panel. Can I set it to default myself? If so how?
It seems to work ok for entry exit though. Despite showing call engineer.
I had ADT call out yesterday but they only wanted to sell me a new panel and a yearly monitoring contract for 500. They didn't want to reset or replace it.
Opening the panel has tripped the tamper and your panel must be on Tamper Engineer reset.
