Replacing Eurosec CP8L keypad
You have a CPX panel not CPL. Your new keypad CPL will not work on your system.... The bit I don't understand is... Your first post shows a picture of a CPL panel with part and full buttons .... Your last shows a CPX panel with two panic buttons instead of the full and part !
ah, ok thanks.
The first photo isn't one of mine but the person who started this thread. Sorry for the confusion.
I'll ahev to source another keypad in that case but make sure the buttons are exactly the same !!
Edit: Just noticed there is a third type of keypad that says Full and Part. Would that one work ??
Does anyone know how to remove Eurosec CP8L keypad?
to clean or replace it?
Remove screw,take front off , remove pcb , clean rubber mat , put back together , test and reset..
Help my alarm will not set
Its coming up can't set.....user master
What is the master code ???
Thanks Dean
