Thanks, a couple of silly questions then-
1. ASD ? i can certainly ask him to check it when he turns up with the ordered parts, which may not even apply
2. If there is overheat stat, is it located where the boiler thermostat control box is, which has the capillary going to it? I can't see in manual any reference, except control box plus thermostat with capillary tube and then thermocouple description, as only things that tell the solenoid when to cut off gas.
So if it is overheat stat, would thermostat change cure that, too basically.
