No, worries, keeps up posted...
OP, you did not seem very confident of the actual measured figures and it seems these were not written down for you and you may have not remembered them well.
Not all boilers will reliably light every time on the first spark.
Boilers are pretty unconcerned and like dogs do what they want to.
Tony
if i remember correctly, these boilers need 2 different types of annual service.
annual service.
then.
every second year service.
both involve the replacement of a burner gasket.
if the service record is unknown then for the sake of safety the second year service should be carried out.
as mentioned explosive ignition could put other parts of the boiler/flue under increased combustion chamber/flue pressure.
not many registered gas operatives are happy to work on powermax boilers.
If all else fails - read the instructions!
I do not know what possessed people who specified these boilers. I bought my house as an ex show home from a famous housebuilder. The Powermax was standing upon a raised platform [why?] in its own cupboard on the landing. It was compartment vented into the loft. The gas valve made a terrible racket. The flue and air intake tubes were completely unsupported, and the flue had come adrift and was discharging onto the ridge timber, scorching it quite nicely. The neutral anticipator in the room thermostat was not connected. There was a constant heat loss from the thing, wasting away up into the loft, day and night, summer and winter.
It was replaced long since by a quality boiler with weather comp installed elsewhere, freeing up the cupboard.
Yes, that was the point I was making. However, the very noisy gas valve was a boiler problem, as were the colossal heat losses.
