- Joined
- 27 Jan 2008
- Messages
- 24,762
- Reaction score
- 2,851
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
You need to ask? How long would you say it takes to get an electrician to attend to sort out a problem which is resulting in no supply to freezer or central heating?What’s wrong with that? We have four ring circuits in our house. Upstairs, downstairs, kitchen, ovens.
My front kitchen has four RCDs supplying it, one for the cooker, with a socket as well, one for most of the front of house, and two RCD sockets on a UPS supply. I can also run extension leads front/rear to keep essential services running, in all 16 RCDs supply the house.
So I can, without needing to get my meters out to fault find, live without any one of the RCDs, repairs can be done at leisure. I have no need to fix before a freezer defrosts, or before I freeze.
One RCD may be OK when you have a fridge that will work on gas, and lights which run on 12 volts, and a gas cooker as with a caravan or boat, but most home rely in some way on having 230 volts power.
I did quote "(Historically, a limit of 100 m² has been adopted.)" this did not really work unless the supply was in the centre working out, the main problem was the change in the rules about drilling beams, 1/3 in before the hole can result in a lot of cable going 2/3 way across ceiling and then up/down the wall, the old traditional split side to side of the home, used less cable to the latter up/down split, which was done to ensure if something happens to cause an RCD to trip feeding sockets, you're not also plunged into darkness.The area is irrelevant; forget about it.
I would call that conductors in parallel rather than a ring final, a ring final can only supply BS 1363 equipment.I definitely do. I have two 20A double pole switches (one for each oven) right next to each other with a short piece of cable connecting the two of them together to make a ring circuit. Both have a 2.5mm cable following the same path back to the consumer unit going to a 32A breaker.
