Hi
Anyway, I am building double wardrobes in the alcoves and behind door number 4 counting from the left will be 4 X full PC towers obviously side on, 1 Tivo, 1 AV Receiver, 42" LCD TV, 5.1 Surround speakers and a Netgear switch.
I doubt very much that all 4 PC's will be on at same time, max 2 but if it does get a tad hot or the temp in my PC get too high i will of course remedy it, first guess a ventilation grill in the void above the PC's that allows the heat into the loft, if I have to use suction then I can simply fit some PC fans to said ventilation grill that only comes on when PC is on
