- Joined
- 11 Jan 2004
- Messages
- 44,603
- Reaction score
- 3,069
- Country
No. But someone else might...But you will never, ever be using all at the same time. For instance you won't be using the hair dryer while in the shower.
From what I can find, the device itself is 20W - one twelfth of an Amp.
In fairness his point was valid nonetheless, which is that simply adding all loads together does not tell us what to expect in the real world.No. But someone else might...
I'm not making suggestions. I simply stated that the standard rule of thumb in Ireland is as described. And they are not all oversized. As I pointed out, 2.5mm^2 isn't always suitable on a 25A device. Nor is 4mm^2 always suitable on a 32A device, etc.Why are you using oversized cables (or lower rated MCBs) for all your suggestions?
Then please go to Electrics outside of the UKI'm not making suggestions. I simply stated that the standard rule of thumb in Ireland is as described.
Yes they are.And they are not all oversized.
When is it not?As I pointed out, 2.5mm^2 isn't always suitable on a 25A device.
When is it not?Nor is 4mm^2 always suitable on a 32A device, etc.
True, in neither case will such cable/OPD combinations 'always be suitable'. However, although 'not always suitable', they very commonly 'will be suitable'. It therefore seems odd that a 'rule of thumb' should be based on an unusual 'bad case'. Are electricians in Ireland not encouraged to think and apply knowledge?....I simply stated that the standard rule of thumb in Ireland is as described. And they are not all oversized. As I pointed out, 2.5mm^2 isn't always suitable on a 25A device. Nor is 4mm^2 always suitable on a 32A device, etc.
I would suggest that 4mm^2 is actually seldom suitable for a 32A protective device. The circumstances where it is suitable are quite limited.However, although 'not always suitable', they very commonly 'will be suitable'.
Methods 100, 101, 102 & 103 for a start, and maybe with other de-reating factors.When is it not? .... When is it not?
Don't be silly John.Are electricians in Ireland not encouraged to think and apply knowledge?
Well, I have to admit that I haven't a clue as to what goes on in Ireland, but 'over here' Method C cable installation without de-rating factors seems common, rather than the 'quite limited' which you appear to be saying is the case in Ireland. Why are the Irish practices different?I would suggest that 4mm^2 is actually seldom suitable for a 32A protective device. The circumstances where it is suitable are quite limited.
Clipped direct is not uncommon per se in domestic installations. However more and more there is a mix in installation methods through an installation.Well, I have to admit that I haven't a clue as to what goes on in Ireland, but 'over here' Method C cable installation without de-rating factors seems common, rather than the 'quite limited' which you appear to be saying is the case in Ireland. Why are the Irish practices different?
Kind Regards, John
