- Joined
- 28 Apr 2004
- Messages
- 18
- Reaction score
- 0
- Country
thanks again Ban-all-sheds.
Ok so ill use 6 / 10mm cable for my extractor spur, and replace the socket spur cable while i'm at it.
I could spur off the ring as you suggest but it would mean more chopping out of plaster and also it would be nice to have the extractor on the 45 amp cooker switch as the FCU for it will probably be hidden.
To clarify what i want to do, as you say I currently have a cable coming from the CU to a cooker control unit (switch with socket) above the worktop and then back down to the cooker outlet plate. The trouble is that the CCU is in the way of where I want to put a splashback so i want to swap it for a single 45A switch (no socket) and move it over a couple of feet.
I will investigate the crimps you mention but i was thinking i could use a cooker outlet plate as a junction box below the worktop?
I hope this is a bit clearer. I think I was confusing terminology before CCU = Cooker control unit not cooker connection unit (cooker outlet plate) as i previously thought.
EDIT: have found some 6.3mm crimps on screwfix http://www.screwfix.com/app/sfd/cat/pro.jsp?id=90867&ts=64984
are these the best thing for connecting 6/10mm cable?
