H
holmslaw
[url=http://radiomagonline.com/media/2009/0309/NASAwire.pdf]NASA TECHNICAL STANDARD[/url] said:NASA-STD 8739.4 with Change 4
...This Standard provides a baseline for NASA project offices to use when preparing or evaluating process
procedures for the manufacture of space flight hardware or mission critical ground support equipment....
4.3 Principles of Reliable Cabling and Wiring
4.3.1 Factors Controlling Reliability. Reliable interconnecting cable and wire harnesses result
from proper design, control of tools, materials, work environments, and careful workmanship by
trained and certified personnel.
4.3.2 Fabrication Principles. All fabrication shall be performed to meet governing engineering
documentation (Requirement).
4.3.3 Splicing. Splicing damaged or broken conductors is not permitted.
4.3.4 Crimping. Stranded wire shall be used for crimping (Requirement).
Crimping of solid wire is prohibited.
Crimping of solder tinned wire is prohibited.
I would never trust a soldered joint.
Why does NASA prohibit crimping of solid wire?
