I'm going to be moving the rad shown below either under the window or with a tall fancy one next to the window. At the same time I'm thinking (well, the OH is wanting) to add a rad to the conservatory which is on the other side of said window. The house floor is wooden, however the conservatory floor is concrete so I'm wondering what the best way of running the pipes is? I've considered taking the skirting board off and running a pipe up through the wooden floor behind the skirt and through the wall into the cons. either completely behind the skirt or if needs be hacking a bit of plaster out above the skirt and putting the pipe behind the dot and dab plasterboard then covering over. I assume I T off the pipes that are currently feeding the rad when I adjust them for the new position. The current pipes are 15mm but I have some 10 in the garage and I'm thinking that it will be easier to hide/get through the wall than the 15? On the cons side we will be plastering so I will probably be able to run the pipe behind skirt alond to the radiator that will be added in there. The cons rad will probably be a short wide one under the windows on the dwarf wall you can see.
Corner where new rad will be to side or under window.
View media item 50802
Inside of conservatory, I've decided to put the rad on the opposite side of the door to this to avoid the soil pipe.
View media item 50803
Any thoughts on this please?
