Hi folks.
Whilst Part H of the Building Regs has absolutely nothing to say about such matters, 1.33 of Approved Doc H says (in relation to AAVs on soil stacks)
Kind Regards, John
Many people will no doubt say that is 'a regulation', although it clearly is not. On the other hand, FloPlast say in their documentation, regarding their AX110 product:"... Air admittance valves should not be used outside buildings or in dust laden atmospheeres.... "
Are FloPlast telling the truth, or are there any other (real!) rules/regulations which would prevent the practice. If it is acceptable, it would save me a very long run of vent pipe, with a very complicated route that would present some access difficulties."Document H Clause 1.31 states that “Ventilating pipes open to outside air should finish at least 900mm above any opening into the building within 3 metres”. This new development by FloPlast, of an External Air Admittance Valve, will allow the installation of an external soil pipe within 3 metres of any opening and terminate at the same height as if it were installed internally, ie. 200mm (minimum) above the highest wet entry point to the soil vent pipe. See diagram below."
Kind Regards, John
