so realistically it would be easier/better to have two seperate cicuits. one for the em lights, run from the existing em lights and one for the normal outside lights run from the existing light circuit.
That's what you said nearly a year ago: //www.diynot.com/forums/viewtopic.php?p=1742643#1742643im an apprentice leky my mentor left
Actually it's not.please dont ask its complicated.
No, but you are not competent enough to be doing the job your employers are expecting you to do.im not completely incompetent
This is a place of work.my boss asked me to do this
You are not being adequately supervised. Asking how to do your job on a DIY forum does not count as adequate supervision.. its a learning curve keep asking until i get the correct answer
This is obviously a public building so the work should be carried out by a professional electrician.
You may have sufficient qualifications however competence comes with experience.
To gain the necessary experience and knowledge you need to be under the supervision of someone with the necessary experience and knowledge, this is where your company is letting you down and breaking the law (Electricity at Work Regulations).... it is the responsibility of your company to ensure yours and others safety, if this meant employing another fully qualified electrician then so be it....Reality of it is you cannot jump into anything with both feet, you need to learn and do everything properly which basically means you need to learn from a competent person, I'm envisaging you are only about 2 years into your apprenticeship? If so it is criminal to expect you to learn on your own.
I get the impression that you are a concientious person trying to better yourself, but I do'nt think you will be able to live with your conscience if you kill somebody, if not with this job then maybe another, & I'm not sure it would be a legal defence. There must be some body that can advise on a better way for you to complete your apprenticeship & would suggest that it might be a good idea for you to seek that sort of advice aswell as the technical type. Also I am not sure how you will prove to have served a recognised apprenticeship in the future if you continue as you are.
Make up your mind.get a life get a wife.
