- Joined
- 18 Sep 2017
- Messages
- 9
- Reaction score
- 0
- Country
Hello One and All,
I have a conondrum in regards to adding some external power. Specifically I have a pond which we have a pump/filter combined so just one cable for this, the device has a 10m cable and I also have conduit to bury it in. I also have an external double power socket which I'd like to add too.
So on an external facing wall I currently have a single power socket and next to it the previous owner has placed an FCU which feeds a sensor patio light on the inside of that wall. So what I want to do is drill directly through the back of these to feed the sockets on the outside wall.
Now this is where I'm a little confused with what's required....
Am I able to spur off of the single socket or FCU to then place an external RCD which the pump cable will be connected?
Then from the side of the RCD am I able to do a short covered cable to supply the external double socket?
The RCD I had seen was this...
http://www.screwfix.com/p/bg-13a-switched-weatherproof-rcd-fcu/20523
With this double socket...
http://www.screwfix.com/p/lap-13a-2-gang-dp-switched-plug-socket-with-outboard-rocker/30139
Answers on a postcard please....
Alex
Alex
