extra points
30 Oct 2002
my cooker is on its own 30amp 6mm radial but there is an additional double point spured off the controll unit, is it safe? do i need to disconnect it or can i just up the fuse in the consumer unit or just change the double point for a fussed double point?
USUALY COOKER POINTS CONTAIN ONE 13AMP SOCKET OUTLET ANYWAY SO YOU SHOULD BE OK WITH ONE DOUBLE UNIT SPURED OFF. IF YOU STILL WANT TO INSTALL A FUSED SPUR UNIT AND DOWNRATE THE FUSE TO 13AMP THIS WILL ALSO INCREASE THE PROTECTION OF THE SPUR..
[Edited by DEANO on 09-11-2002 at 16:35 PM GMT]
