Heaven forbid anyone should put them right.
They are always right, especially if you want a completion certificate
Unfortunately, that is the name of the game - at least, the game which leads to the quietest life.The idea is to keep them sweet.
Probably true - but that really isn't (shouldn't be) the point.How difficult and costly is to fit a fan isolator? A small price to pay to avoid further arguments.
Indeed - but it really shouldn't be like that. In a sense they are 'blackmailing' us, by deterring us from challenging iffy views/decisions on their part, in the name of 'a quiet life'!Never pick a fight with your BCO ... My BCO have odd interpretations about smoke alarms - just accept what they want is the easiest approach
They are clear. Local isolation is not a requirement for any appliance - not even a shower nor a cooker.If, and say IF the regulations were written clearer centrally, then these issues wouldn’t happen
Partially true - but if one wanted to minimise the scope for BCO interpretation/discretion, the regs would have to be much more detailed/'comprehensive', and largely 'prescriptive' - which could introduce a whole new set of problems.If, and say IF the regulations were written clearer centrally, then these issues wouldn’t happen
You are perfectly free to have these items if you so wish - BUT - they are not mandatory.One point to consider it the fan has an over run or a humidistat etc etc and said fan catches fire or gets soaked in water or needs cleaning etc etc a you do not want to turn the light off then a 3 pole switch interrupting all lives and allowing the user etc to carry on safely can be a help rather than throwing the mains off. Put this switch in a not easily reachable place though to deter unreasonable switching off in normal use.As said it is another point of potential failure and might be left permanently off thereby defeating its intent. You can not always win every situation but just develop the least worst of most situations (in theory).
Personally I am on the let’s have an isolation near the ceiling for such things, I am also in favour of having a reliable means of switching off a cooker or shower etc with the switch near and obvious too. In fact for under unit appliances if the plug ends up underneath a worktop am behind it say then I prefer some switch above the worktop- with that one you could achieve a similar outcome But a flex disappearing thru a hole in the worktop would look a bit naff
Which bit aren't you sure that you agree with?Not sure I agree with you.
For a start, I'm not sure that I understand your 'qualification', since the same would be true even if the fan did not have an over-run or humidistat, wouldn't it?One point to consider it the fan has an over run or a humidistat etc etc and said fan catches fire or gets soaked in water or needs cleaning etc etc a you do not want to turn the light off then a 3 pole switch interrupting all lives and allowing the user etc to carry on safely can be a help ...
Like a light switch? It would be handy I suppose.do you believe that each should have a local 'isolator
Electrically it's pretty trivial. Physically it may or may not be.How difficult and costly is to fit a fan isolator?
If I wanted to comply strictly with BS 7671, 'isolation' would have to be DP in my (TT) installation - and none of my light switches are DPLike a light switch? It would be handy I suppose.
I take it you realise in building regs it is mandatory to provide ventilation in some situations? If natural ventilation is not possible in those situations then ducted and/or forced ventilation is mandatory.You do realise that even fitting the fan itself is not mandatory.
