Oh dear....Although the pump is better on the flow, it would still work if you did the 45 modification but just left the pump on the return for the time being.
Tony
I decided then to close the valve coming out of the f and e tank feeding the heating circuit and the water coming from the vent
When draining, valves are opened. There is no reason to have a valve where you have put it.the valve was only put in for future draining down it's a full bore gate valve on the feed to the heating system from the f and e shouldn't do any harm
